[video=youtube_share;UEDA-g4WIEE]http://youtu.be/UEDA-g4WIEE [/video] Stock Stuff New Recalled Front Master Cylinder…………85 Seat………….25 Ram Air Tubes…………….50 Gas Tank Black some damage to filler spout area not pictured………….200 Gas Tank Pictured………….200 Fuel Pump…………………65 Complete Key Set Ignition cap and rear lock…………..125 Clip Ons………………….40 ea Triple Tree…………………100 Forks......................200 Radiator.................145 Clutch Perch………………….15 Clutch Lever..................10 Front Brake Master………………65 Front Brake Lever……..15 Rear Brake Master………………20 Stock Front and Rear Brake Lines…………5 Rear Rotor……………20 Front Rotor………….40 ea Front Calipers………………..20/pc Rear Calipers…………………15 Carrier/Hub …………30 Front Axle…….15 Rear Axle………15 Front Spacer………10 Rear Spacers………..15 Gauge Cluster 5060mi (lots just ask for mileages)……………..180 Fairing Stay………………..NEW……85 Front Short Harness…………….45 Rear Short Harness…………….20 Stock Headers………………..45 Rear Muffler……………….50 Left Accessory High/Low Beam……………25 Right Accessory Starter…………40 Harness………………..75 08 600 Frame with 5k mi ……………….1700 Motor with 5060 Miles……………..800 Throttle Bodies...........................85 ECU..............................140 Swingarm………………..45 Swingarm w/broken spool mount……..25 SubFrame complete………………….195 SubFrame Rails L&R 06 07……60 Battery Tray……….20 Black Undertail ……..10 Shock……………20 Links……………20 Kickstand………………….40 Stock Rearsets…………..45 ea Shifter Assembly ……….35 Speed sensors……45 Turn Signal Relay…..20 Fuel Pump Relay……25 Tank Side Covers..............20 ea Front Fenders...........45 Rear Huggers........20 THE GOOD STUFF which is ALL NEW the bike was never ridden Flashed ECU......................200 Scorpion CF Shorty slip on with Cat Delete………….150 Two Brothers Shorty Exhaust (Not pictured)….175 PCIII……150 Danos Stand Alone Quick Shifter Pull (GP Shift)……….220 Bazzaz TC Unit…….SOLD Bazzaz Map/TC Switch……..SOLD BMC Air Filter……45 K&N Air Filter…25 50mm Clip Ons Silver………………….85 RaceTech 25mm Carts (In Forks) FRSP 54031 with Fork Extender……..675 comes with oem carts also RaceTech GS 3 Rear Shock with Remote………….650 Ohlins Linear Steering Damper…SOLD GPR 4 Black Rotary Stabilizer…………….215 Ohlins 25mm Fork Caps (non extended)…..75 Ohlins 30mm Fork Caps (non extended)….75 Brembo Front Master Reservoir........45 Galfer Rear Rotor………….80 Galfer Full Floating Front Rotors DF48CW Just Put On……450 Pazzo Levers Black Shorty Silver Adjusters F&R…..SOLD Pazzo Black Long Clutch.......65 (Used) CRG RC2 Long Black Levers red adjuster…………….110 Assorted Aftermarket Levers Short and Standard….Ask SS Brake lines Front white silver or black Goodridge, Spiegler etc...............60 SS Brake Rear lines white or black...................35 Vortex Rearsets Black Folding Levers…………..240 Vortex Sprockets 45 Black……………25 Many others just ask Track Fairs Upper Tail Lower and Fender……225 Pictured Track Fairs Black Yellow SBK Tail……………..275 Zero Gravity Clear Windscreen………..40 Clear windscreens…………..15 Race Rails Black…………75 Yoshimura NEW Harness….450 Vesrah SRJL Front Pads…………….85 Moto-R Black Stator Cover…….75 HPS Billet Stator Cover………..85 NRC Stator Cover……………..85 Myrtle West Lower Link SU105.............75 Clutch Case Protector Gold…….25 Stator Case Protector Derlin Slider………25 Woodcraft Sliders one rashed and broken……………35 No Cut Sliders…………………….45 Black OEM Rearsets and Passenger Pegs….140 Healtech Xtre XT-501 Timing Retard Eliminator……….55 Healtech Speedo Healer………………….60 Cox Radiator Guard Black…………SOLD Tech Spec Tank Pads……………..20 Dunlop NTEC 200/55 KR449 Rear……………. Dunlop NTEC 120/70 KR448 Front………… Take Off Dunlop NTEC Front 120/70 UK Tire………… Michelin Pilot Power 3 180/55 120/70…………
