Just got this one in. Had been waiting for it for a while. A friend was building it over time and just gave up on it. Everything on it is NEW except what I have stated in the Good Stuff. I've got some stock stuff for it as well as others that are listed as well. He went way high end on this. The motor was built by Tom Housworth. Even the exhaust was picked up from Martin Cardenas's crew chief. Custom AMA built pipe. Beautiful coloring on it. Pics and list below. Need anything feel free to ask or email Chidadog@gmail.com Tx Guys Stock Stuff Seat………….30 Ram Air Tubes…………….50 Gas Tank Blue…………200 Fuel Pump…………………65 Ignition w/key and cap …………..100 Clip Ons………………….40 ea Triple Tree…………………100 Forks......................200 Radiator.................130 Clutch Perch………………….15 Clutch Lever..................10 Front Brake Master………………75 Front Brake Lever……..15 Rear Brake Master………………20 Stock Front and Rear Brake Lines…………5 Rear Rotor……………30 Front Rotor………….50 ea Front Calipers………………..20/pc Rear Calipers…………………15 Front Rim ……………………..200 Rear Rim ………………………150 Carrier/Hub (750) …………30 Front Axle…….15 Rear Axle………15 Front Spacer………10 Rear Spacers………..15 Gauge Cluster……………..150 Front Short Harness…………….40 Rear Short Harness…………….20 Stock Headers………………..60 Rear Muffler……………….50 Left Accessory High/Low Beam……………25 Right Accessory Starter…………35 Front Seat……………….25 Swingarm………………..45 Swingarm w/broken spool mount……..25 SubFrame with repaired but straight box………………….150 SubFrame Rails L&R……60 Battery Tray……….20 Black Undertail ……..10 Shock……………25 Links……………25 Kickstand………………….40 Stock Rearsets…………..45 ea Shifter Assembly ……….35 Speed sensors……45 Turn Signal Relay…..20 Tank Side Covers..............20 ea Front Fenders...........45 Rear Huggers........20 THE GOOD STUFF which is ALL NEW unless noted. The bike was never ridden Attack Rearsets.... SOLD Attack Triple with All Eccentrics......700 Bazzaz TC/ZFI......SOLD Bazzaz TC/Map Switch....90 Bazzaz TC Light......SOLD Bazzaz ZAFM.........200 Bazzaz Zbomb TRE.....45 Dynojet Ignition Module (used).........SOLD Dano's QS Sensor for DJ Ignition Module.......150 Brembo RCS w/Folding Lever......300 Brembo 19x20......230 (used) Brembo Reservoir........45 Brembo HP Full Floating Front Rotors 310mm 70.1517-B (used)....450 CRG SuperSport Clutch.......120 (Used) Driven Gas Cap.....SOLD Driven Gold Spools....25 Driven Gold Swingarm Blocks/Adjusters with Sliders......80 No Cut Sliders.......40 BrakeTech Full Floating Front Rotors Axis/Iron 310mm.........600 BrakeTech Full Floating Rear Rotor Axis/Iron.......185 Braking Rear Rotor.............65 Ferodo Front Pads.....85 Spiegler 3-1 White Front SS Lines...............85 Spiegler Rear White SS Line...................45 Remember all this stuff is NEW unless stated M4 Full TI Custom AMA Exhaust (Martin Cardenas’s Bike) M36 but shorter can and mounted lower....950 17" Marchesini Magnesium Rims w/Carrier and AFAM 43 T Sprocket NEW.....2800 Ohlins 30mm Carts Installed w/ 1.0 springs gold valving.....1100 Ohlins Black Fork Extenders.......200 Ohlins SU789 Mk 2 TTX Rear Shock Newest Model 1.0 Spring with Box.......SOLD Scotts Steering Stabilizer New in Box.........350 Vortex Black Stay.....SOLD Yoshimura EMPro........475 Yoshimura Cable and software..........250 Yoshimura STR-S Cams w/adjustable sprockets.........600 Ported and Polished Head Mild Milling...........600 Woodcraft Right Side Case Protector.............85 Woodcraft Left Side Case Protector...............85 Votex Black Fairing Stay...................SOLD Shorai 4871 Lio Battery..........SOLD Ballistic 8 Cell Lio Battery (used)..........85 Armour Bodies Fairings Unpainted or drilled...........SOLD ChickenHawk Warmers Single Temp (used)...............275 NTEC Take Offs DOT 120 190/55 F/R UK’s 3 complete sets...........150 ea set NTEC Take Offs DOT 190/55 Rears 2.............90 ea Kyle Racing Black Clipons...............SOLD K&N Air Filter (used) Cleaned and Charged........35 BMC Air Filter (used) Cleaned and Charged.......45
