Just got in an 06 GSXR 600 Track Bike (Thank You Bob) That's got some goods on it. 6754 mi. See anything or need something you don't see shoot me an email Chidadog@gmail.com I've probably got it. Stock Stuff Seat………….30 Ram Air Tubes…………….50 Gas Tank Blue………SOLD...but have others Fuel Pump…………………65 Ignition w/key and cap …………..100 Clip Ons………………….40 ea Triple Tree…………………100 Forks......................200 Radiator.................130 Clutch Perch………………….15 Clutch Lever..................10 Front Brake Master………………75 Front Brake Lever……..15 Rear Brake Master………………20 Stock Front and Rear Brake Lines…………5 Rear Rotor……………30 Front Rotor………….50 ea Front Calipers………………..20/pc Rear Calipers…………………15 Front Rim ……………………..200 Rear Rim ………………………150 Carrier/Hub (750) …………30 Front Axle…….15 Rear Axle………15 Front Spacer………10 Rear Spacers………..15 Gauge Cluster……………..150 Fairing Stay..............50 Front Short Harness…………….40 Rear Short Harness…………….20 Stock Headers………………..60 Rear Muffler……………….50 Left Accessory High/Low Beam……………25 Right Accessory Starter…………35 Front Seat……………….25 Swingarm………………..45 Swingarm w/broken spool mount……..25 SubFrame with repaired but straight box………………….150 SubFrame Rails L&R……60 Battery Tray……….20 Black Undertail ……..10 Shock……………25 Links……………25 Kickstand………………….40 Stock Rearsets…………..45 ea Shifter Assembly ……….35 Speed sensors……45 Turn Signal Relay…..20 Tank Side Covers..............20 ea Front Fenders...........45 Rear Huggers........20 THE GOOD STUFF which is ALL NEW the bike was never ridden Bazzaz TC/ZFI......SOLD Bazzaz TC/Map Switch....SOLD Brembo 19x18 slight bent lever ......210 Brembo Reservoir........45 Brembo HP Full Floating Rotors 310mm 70.1517-B (used)....450 Galfer Rear Rotor………….80 ASV Levers Black Shorty Silver Adjusters F&R…..SOLD CRG SuperSport Clutch.......120 (Used) Driven Gold Spools....25 Driven Gold Swingarm Blocks/Adjusters with Sliders......SOLD No Cut Sliders.......40 Front SS Double Lines...............60 Rear SS Line...................35 K&N Air Filter..........30 BMC Air Filter.........40 Ohlins 30mm Carts/Forks .....825 Ohlins Silver Fork Extenders.......175 Ohlins SU789 Mk 2 TTX Rear Shock Newest Model 1.0 Spring .......900 Ohlins Steering Stabilizer…………200 Scotts Steering Stabilizer New in Box.........350 Vortex Black V2 Rearsets w/folding levers……SOLD Yoshimura EMPro........475 Yoshimura Cable and software..........250 Yoshimura STR-S Cams w/adjustable sprockets.........600 Ported and Polished Head Decked...........500 Woodcraft Right Side Case Protector.............SOLD Woodcraft Left Side Stator Cover...............SOLD Woodcraft Sliders……………SOLD Woodcraft Clip Ons…………..SOLD Vortex Black Gas Cap……………60 Ballistic 8 Cell Lio Battery (used)..........85 Motion Pro Revolver Throttle w/ Discs………..SOLD Motion Pro Kill Switch…………SOLD Akropovic Full TI CF Can (some cf broken on top) with CF hanger……….SOLD Driven 45t Sprocket………….SOLD Optimal Body SS tail...........325 Clear Windscreens……….30 ea ChickenHawk Warmers Single Temp (used)...............275 NTEC Take Offs DOT 120 190/55 GPA complete sets...........150 3 Sets of Rains Michelin, Dunlop, Bridgestone……………150 ea
